2003 2500 quad cab question for road trip?
FENDER LINER kit=LMC TRUCK
Light troubles
Hi I've been lurking for a while. I have had an 03 2500 quad 4x4 for about a year now with 95k on the clock I'm preparing for our first road trip and was wondering if anyone has ever compiled a list of recommended tools to bring for road repairs , don't have room to put the whole role away in the bed. Knock on wood I've had no problems at all so far ,so as far as tools it's only needed stuff for oil change and fuel filter also rear ujoint and grease all fittings also any other parts you might bring on the road?
Much thanks in advance
Tony
It's been said all you really need is Duct tape and WD40. If it moves and it shouldn't use the Duct tape. If it doesn't move and it should use the WD40 :)
It really depends on how far off the beaten track you are planning on going, how much you are comfortable in repairing the vehicle on the road and if you have done any recent repairs. Basic hand tools, tie straps and bungee cords, booster cables, cel phone, auto club card, spare fuel filter. Everyone's list is different.
David
You don't want to see my list for Tools and Parts.... but it is always hard to set the pace.
100Lbs on Parts and Tools.
But I travel really remote areas.
Geno's Garage sells something called a boonie box that contains the common spares you might need while on the road.
Check all the basics like belt, water pump, tensioner, coolant hoses, ujoints, and all fluid levels. It's easier to fix it at home than on the road. Jumper cables, fuel filter, tow strap, basic tool set, and good spare tire. Spare water and good flashlight and cell phone charger.
The boonie box is a good item to have on a trip, and is reasonably priced. One thing I would definitely recommend is a spare serpentine belt. It's one of the easiest roadside fixes you can do (20-30 minutes), and when one goes it pretty much shuts you down on the spot when you lose rotation to the power steering and water pumps in addition to the power brakes. Shortly after I bought my truck I bought a couple of 3" sink drain test plugs from Lowes and used them to plug the frame tube that sits just forward of the rear wheels. I rolled up some basic tools (ratchet, extensions, 1 1/8" socket for the fuel filter canister, screw drivers, pliers, etc) in a couple of rags and stuffed the bindle into the frame tubes. When the plugs are tightened the rubber center expands and seals the frame tube from the elements, so water and dirt never get inside. I've used all the space under the back seat, plus I don't like the idea of getting grease on the inside of the truck. One other thing you might do is check to see, and make a note of all the Cummins parts/service centers that will be near you on the trip. They carry pretty much everything related to the engine, and will also do engine repair work on any vehicle with a Cummins engine.
