I'm thinking about buying a 2003 3500 HO 4X4 SRW Quad Cab Long Bed and would like any member opinions on the following:
1. Any opinions about the new auto transmission and towing up to 13,000lbs (I have a 5 speed now, but might consider the auto... if it is up to the task).
2. Is the bed any higher then the 2001 4X4 (I didn't have to flip my 5th wheel axles to tow with my 2001, but it could be a problem if the bed is any higher with the 17" wheels etc. ).
3. Are the stock trailer towing mirrors adequate or will I need to get the extension mirror option.
4. Is the new gear ratio (3:73) enough for towing a 13,000 5th wheel, or is the 4:10 needed. If you don't think it will work well with the auto, how about the 6 speed.
5. Any "must have" options, that you did get or didn't get but wished you had.
