I have a stock 2003 Auto 2500 5.9. Bought used with 105,000 miles on it.I now have 110,000 miles and have noticed increasing longer cranking times. Batteries good cranks fast.Had truck evaluated at repeatable shop locally they said lift pump pressure a little low but all else good asked them to torque crossover tubes which they did and said were a little loose.Have ordered a Geno's garage carter pump replacement Baldwin 5 micron fuel filter.But am looking to further troubleshoot possible injector wear issues before I have no start conditions. Read a lot different things to look for here but want to dumb it down to make it simple and do not want to damage truck while doing so.Since I'm doing this blind .
Also codes P0111 and P2509 keep coming up.
But just hauled a new 5th wheel toy hauler from South Dakota to Seattle with no problems other than slightly increasing longer start times.
To raise rail pressure i can unplug FCA to get maximum rail pressure and see if I get a faster start. To overcome any leak-by.
If successful. Then plug back in FCA. And then cap (with what?) Pressure relief valve or better yet it will be easier to disconnect which line ?and look for fuel. If return line to CP3 Pump do I have to plug pump where line was disconnected?
Willing to but parts that have a wear factor anyway to replace before buying new Bosch injectors.
