2003 5.9 High Pressure Fuel Lines
Why should we avoid using remanufactured injectors?
TPS /APPS Cover attaching pins....parts diagram
Hi again,
In my long-drug-out build of the 2003 5.9 I consider the "sterility" of the parts I will be attaching to the engine.
The original lines that connected to the connector tubes were purchased new. The mechanic responsible for the mechanical damage to the parts should be arrested. The seats were even damaged, dimpled and galled with burrs sticking out, ready to be eroded and transported to the injectors.
Now I look at the fuel rail itself. It actually looks quite good, some corrosion, and a little damage to at least one of the seats. I am quite convinced that the high pressure of the Common Rail is nothing like wrenching on an old Chevy, or even an old Mercedes for that matter because the capability of the pumping system exceeds the design of the injectors in typical use. For the price, they just don't seem to get the mileage one would hope to rack up.
The owner doen't seem ready for a Fass or Airdog, he is eager for this truck to get to work and pay for it's expensive habits, and I am concerned that the current injectors may be about to have a near-death experience based on the one that has already failed. I would at least like to assemble a dual filter system for this engine out of some stainless pipe and a couple of remote filter bases form NAPA.
Just about every part in this engine is being replaced with Cummins parts.
Since I am building this engine to last, I naturally want to suggest a new fuel rail. However, I am wondering if a competent injection shop could clean this and it would be OK to install.
snapped bolt
Rails can not be cleaned and must be replaced. If the rail has rust inside, the entire fuel system should be inspected, cleaned or replaced or you will have another failure.
As I am thinking through...
The CP3 that arrived on this engine also was "in a flood". The engine was run for an undetermined amount of time after the flood. The is rust
spotting on the steel parts in spite of the protective coating.
I opened up the fuel filter body and found a lot of debris, and of course what appears to be silt transported from other areas upstream of the filter. Of course, the owner said the CP3 was working fine when he shut the engine down. I am thinking it was probably pumping a fine grinding compound through the high-pressure side of the fuel system.
I am thinking that the CP3 should be cleaned, or rebuilt, or replaced with a new unit.
snapped bolt
