no but i did for 150k on my 99'.
Originally posted by b. ferrara
What are the rpms at
70 mph with the 373 and with the 410 thanks guys.
Originally posted by Jeremiah
This is Jeremiah. I think 70 mph is 2200 rpm in 6th gear. Can't tell you about the 4. 10. Will let you know for sure tomorrow about the other.
Originally posted by jimnance
The reason for driving hard at break in is to assure good ring seating. Within reason high cylinder pressure (read power output) presses on the rings harder which in turn forces them tighter against the cylinder walls. Anyway, the net result is you usually end up with better long term oil comsumption and compression.
Beware, sustained high RPM or lugging the engine are both bad for break in. A nice 70 MPH freeway run up and down some hills for a couple of hours would be ideal.
Contrary to popular belief, 90% of the breakin is done in the first 500 miles.
I should be in good shape then. The first 100 was climbing out of Denver. I've got 1000 on it now and am getting to drive to NW Arkansas for Thanksgiving. That'll be done at 70-75 mph. My problem is not having a load to pull (other than the truck, which weighs 7880 with me and two Portuguese water dogs sittin' in it.
Originally posted by mgonske
As of the last fill, I was at 5119 miles and 309 gallons, for an overall average of 16. 5 MPG.
High tank was 17. 7 MPG; low (not counting a 6-gallon fillup) was 15. 7 MPG.
Mini Trip Computer tank averages have always been high, ranging from 0. 1 to 2. 1 MPG (again, if I discount two under-10-gallon fillups), usually somewhere in the one and a half MPG range. I don't see any way to calibrate it.
I don't think of myself as that much of a leadfoot, but it seems like no matter what vehicle I drive, I get considerably worse fuel mileage than what others claim for the same vehicle.
