I have a 2004. 5, 3500, 4WD, club cab, long bed, six speed, locking 3:73 rear-end. I have been experiencing what I consider as excessive gear slack in the drive train. I believe it has been there since day one but it is getting more noticeable. I know the usual cause is a sloppy universal joint, but they are OK. Another cause could be excessive ring and pinion gear clearance, but my dealer pulled the cover and this checked out OK. My dealer is telling me that what I am experiencing is an accumulated drive line slack which includes slack from the clutch, transmission, transfer case, two piece drive shaft universal joints, drive shaft center carrier bearing and splines, and finally the differential. This sounds possible, but still not acceptable. I have had many stick shift trucks before, but never a 4WD or a truck as heavy duty as my new Ram, so it could be a normal condition, I don’t know. It’s really annoying hearing the clunk every time I up-shift. Has anyone out there experienced the same problem?
