I wonder it maybe it's loose, did you or could you access bolts to tighten?Bglidewell, no I haven't fixed the leak yet. I bought the seal and haven't got around to it. I need to remove the A/C compressor and I expect to have to do some cleaning on the block side to get a good seal. Will probably not do it until the next coolant change in a couple of years. The leakage is not that significant but it does show up where you state, either dripps off the cornoer of the A/C compressor bracket or the oil pan flange. Ken Irwin
