2006 5.9 aftermarket turbo
3rd gen 2WD LOW ??
'04 Tows 3500lbs Like Crap!!!
there are a ton of choices for twins, I would look into Olee pooles, Ind Inj, first, the BD's are a bit tight for 700 fuel only I think. Just ask around theres a ton of info here.
But like stated before, no single will support 700HP and tow very well, you need twins.
Call Rip at Source Automotive.
503-654-9004
I have a friend with a set of his twins that is about to break 800HP on #2 only.
Twins, for sure.
The cleanest setup I've seen is from J and H Performance in Redding, CA.
They'll be getting my truck when I do my twins.
im not looking to buy twins. twin setup is to much$ i need a single turbo setup i have ddp 90 hp nozzles and 150 gph fass pump goerond bross trans banks 6 gun banks intercooler and shes puting out 556 hp and 934 tq to the wheels
Are you currently using the stock turbo? What are your EGTs? Unless you chip is "backing off", I do not think you will gain much just by changing your turbo.
