MoparDave is right. You don't need to get it red hot, even a propane torch will heat it up enough and the plastic will start coming out of the hole they use to inject it. You might have to heat it a couple times as your pressing it. I always used a socket and a vice to pop the old ones out.
the new U-joints had a clip machined into the cup on the inside. once you pressed the cup in, you slide the clip on, then move it out a little so the clip has pressure on it.
But they might not make those U-joints as a replacment for the dodge yet?
Someone else said there was groves machined into the outer edge of the driveshaft hole that the cup presses into?
I just checked Napa online and Autozone, both show no u-joints yet for the 06. Sooner or later the company that makes U-joints for the aftermarket will be making them.
