Peter told me that with the new 3400-3600# pressure plate the OFE will hold 550hp. I hope so, as it's what I dynoed at last. So far so good.
If you want a fast shifting clutch that's easy to drive, get an OFE or FE. If you know you're going to beat on it, get an FE. It will take more abuse than the OFE, but may be a bit grabby while backing a trailer.
If you're drag racing and plan to do 3000rpm 3rd gear launches, you'd be better off with a dual disc. The dd clutches do shift slower, are loud, and sometimes need to be finessed into gear at stop. The organic dd has less rotating mass than the feramic or ceramic clutches, so it does shift a bit quicker. The trade-off is that you won't be able to sled-pull with it. Building boost by slipping the clutch is not an option either with the organic. I was told you need a quick spooling turbo and enough fuel to get the clutch hooked up quickly, as in a couple of seconds. Otherwise it overheats.
The feramic and ceramic dd's can take that kind of abuse.
I'd say go with a single disc unless you are absolutely sure you're really going to punish your truck. I went with a dd first, and now have an OFE. I'm happy with my decision.
Additonally, I have to say Peter is an awesome guy to deal with. He stands behind his products 100% and will get you into the right clutch for your application.
