I just had my 2006 G56 input shaft bearing replaced- 44,000 miles? What gives with that?
south bend makes the best kit. it has a solid flywheel with a real pilot bearing , disc , pressure plate and new hydraulics<!-- google_ad_section_end -->
I agree that south bend is the best clutch on the market... but if anything, that would cause the input bearing to go out sooner.
The solid flywheel allows much more NHV to be transmitted to the input shaft than the stock dual mass flywheel. Compensating with a Fluidampr helps some, but damaging torsional vibration still exists that provide accelerated wear to the input shaft bearing.
--Eric
