2006 transmission lines replacement
New Turbo advice
Torque Converter Cooler/Heat Exchanger Issue
Any suggestions for making this an easier job?
Do you need to remove the fuel filter to get the lines behind it installed?
Any short cuts?
Remove the fender liner and you can get to everything. Backup wrench on the heat exchanger and be careful or you will break the solder joints and hose the trans.
The quick connects aren't, they suck. If I ever have to fix a line again it is getting JIC fittings and flexible line.
