2007 3/4ton gears
hubcaps for H2 rims?
Adding 2 micron filter/ nothing else ?
I have looked at several places but can not find any gears for my new truck. It has 37in tires with auto transmission and need to find a 4. 30'ish gear for front and rear of truck. Does anyone have a line on gears. Has 11. 5 rear aam axles. I think the front is 9. 25 but not totally sure.
I thought of that but do you think my RPM's will be too high going down the freeway? I would still like to get some MPG out of it.
even with my 35's and 3. 73 gears i'm at 2000 rpm at 70. depends on the kind of driving you will most likely be doing and the state hwy speed in NM. in my opinion 4. 10's would be my choice for 37's.
The autos have a higher od than your 6spd. Mine is about 2krpm at 70 with 35's and 4'10s.
Bob
I found Klenger's gear ratio/tire size chart and played with it for a bit. If I did it correctly w/ 3. 73, and 37in tires @ 1700 RPM in overdrive I am doing 73MPH and with 4. 10 gears, 1700 RPM would be doing 66MPH. 4. 10's might be where I need to be but to bring it down to the original gear (37's vs 265x70x17's) I would need to go to 4. 34 gears. I am affraid that 4. 56's will be too much. Maybe I am just being a pain in the hind end, I just don't want to burn up the transmission when I am pulling a trailer. Looking at buying a boat when I sell my 5th wheel.
3. 73's
47RE/48RE 4 Speed Automatic
Gear 1 2 3 4
RPM 2. 450 1. 450 1. 000 0. 690
1000 12 20 30 43
1100 13 22 32 47
1200 14 24 35 51
1300 16 26 38 56
1400 17 28 41 60
1500 18 31 44 64
1600 19 33 47 68
1700 20 35 50 73
1800 22 37 53 77
1900 23 39 56 81
2000 24 41 59 86
2100 25 43 62 90
2200 26 45 65 94
2300 28 47 68 98
2400 29 49 71 103
2500 30 51 74 107
2600 31 53 77 111
2700 33 55 80 115
2800 34 57 83 120
2900 35 59 86 124
3000 36 61 89 128
3100 37 63 91 133
3200 39 65 94 137
3300 40 67 97 141
4. 10's
Gear 1 2 3 4
1000 11 19 27 39
1100 12 20 30 43
1200 13 22 32 47
1300 14 24 35 51
1400 15 26 38 54
1500 16 28 40 58
1600 18 30 43 62
1700 19 31 46 66
1800 20 33 48 70
1900 21 35 51 74
2000 22 37 54 78
2100 23 39 56 82
2200 24 41 59 86
2300 25 43 62 89
2400 26 44 64 93
2500 27 46 67 97
2600 28 48 70 101
2700 30 50 72 105
2800 31 52 75 109
2900 32 54 78 113
3000 33 56 81 117
3100 34 57 83 121
3200 35 59 86 125
3300 36 61 89 128
hey bob don't want a ******* match. but if you mount that tire on a 8 inch rim maybe, then put it on a nine inch rim, then ten. does the tire still have the same height? how about running 35lbs of air versus the 65lbs max. just from my experience there is to many variable's in tire height.
No match intended :) but the Toyos are pretty much what they say they are and . 1-. 2 doesnt amount to a hill of beans. :-laf :-laf
Bob
And I don't mean to nit pick either . . . but what you actually want to look at is static loaded radius or something like that. The tire is probably only 37. 1 inches tall on the specified rim unloaded - the radius (which is really incorrect at this point) is different from center to top and center to ground.
I looked at Pro Comp website and they claim the 37x13. 5x20 tires which i have have an overall height of 36. 8 inches.
4. 30's do not exist for these trucks. If you have 37 inch tires, 4. 10's work pretty well according to customer feedbacks. I would only suggest 4. 56's if you tow heavy loads all the time and your speeds are 50-65mph on the highway. And yes the diesels have a aam 11. 5 rear-end and a aam 9. 25 reverse rotation diff in front.
THe more I am reading on here from your advise the more I am going to go with 4. 10's. Anyone have a good source for those gears?
