2013 oil filter and block heater plug access
Ok to use diesel fuel conditioner on 2013 2500 Ram?
iPhone 7.0.2 update don't GO PAST this version IT won't work!!!!
Kirwin
I was trying to figure out how to access the block heater to install the cord I got from Geno's and see if there was a way to get that pesky oil filter out of the maze of hoses and tubes that they have all over the engine that makes it nearly impossible to actually touch the oil filter, let alone get a wrench on it. I removed the passenger side wheel liner like someone else suggested here on the TDR, but still couldn't touch the filter, or reach the block heater just aft of the filter. So I loosened the hose clamp on the air filter cover along with the 3 screws that hold the air filter cover on, left the wires connected and flipped the cover over and set it on top of the engine. Then I had to see how the active air works, so I pulled the air filter out and low and behold there are two interconnected doors it the bottom of the air box that either let air in from the grill, or from a section of approximately 4" duct that is in the top of the fender pointed dirctly aft. Looks kind of weak to me, all plastic, with a plastic ball and socket connection between the two "doors". Then I loosened the hose clamp just above the 90 degree elbow on the front of the turbo and pulled out the piece of hose that runs between the air box and the rubber elbow connected to the turbo. This piece of hose has the silencer and an air guide like plastic piece in it. This still did not allow me to reach the block heater but did start to uncover the oil filter, but not enough to be able to remove it without spilling any oil while doing so. I then decided to go for broke and remove the elbow itself from the turbo. This requires you to disconnect the PCV hose that taps into the elbow just before the turbo inlet. It has a constant tension clamp on it that I had to access through the removed wheel well liner. This is a silicone hose and was surprisingly tight on it's fitting and took some purswasion to get it loose from the metal tubing coming from the valve cover. I turned the clamp so I could access it from above next time. With all this removed, I could access both the oil filter and the block heater connection with ease. Installed the block heater cord, routed the wire out to the right side tow hook, and tied it off. I looked down in the elbow where the PCV hose connects and the elbow is already damp with oil film. I took a picture of the oily spot for future reference. Kind of disappointed that the truck is already introducing oil into the air inlet with only 2,200 miles so far. While it was in there, I installed a A/C condensate drain hose to direct the water away from the frame, attached the radiator hose that runs between the overflow bottle and the water pump inlet connection to its support that had not been made up at the factory, thus leaving the rather large hose unsupported under the passenger side battery as another member on the TDR had found in his truck. Put it all back together, realized that the air inlet hoses all have "keys" so you can put it together outside the truck and then put it back in the engine bay and connect all the tubing at once. Next time I will disconnect it at the turbo and the air box and leave the center connection intact. I did have to shorten the PCV hose about 3/8" it order to make the elbow seat correctly on the turbo inlet. I also changed out the 3 push pins used to hold the wheel well liner in place with 5/16" body bolts to make removing it in the future much easier. I'll try to post some of the pictures I took. Ken Irwin
Ken,
I installed the plug from Geno's on both my 2013 and my wife's 2013. All I did was to remove the air intake tube between the air box and the turbo. That allowed me enough access to install the plug. It's a bit tricky and I had to do it by feel, but it can be done. As for removing the oil filter, it is best accessed from underneath the truck using 3/8" ratchet with a long extension and a cup type filter wrench that fits over the flutes on the bottom of the filter.
Hi Timothy, it's literally impossible to access the oil filter from below on a 2013 3500 truck. There's a large metal crossmember that blocks this access. The frame on a 3500 is very different from the 2500 in 2013. Fortunately, I was able to reach through the wheel well to install my heater plug. Seems like RAM expects you to service the oil filter through the side but I don't see this as working out so well. Seems like most of the 3500 owners and the 2014 on up heavy duty owners are looking to removing the intake tube and servicing the filter from the top.
Tim, I will be removing the air supply hose between the air box and the turbo to change the oil filter on my truck. The purpose of my disassembly was to determine which was the best way, and due to the frame redesign on the 3500s, it is no longer accessible from under the truck. Additionally I'm a neat freak and do not want any oil spilled on the side of my engine, thus the need to provide good actual access so that I can keep the filter vertical while removing it. I'm not convinced that you can actually get it out from the wheel well at all. Certainly not without making a mess. Ken Irwin
Pics
Here are the pictures.
Ah, I did not know about the difference in frames between the 2500 and 3500. That does sound like a real PITA!
Ken, thanks for posting the pics!
Kirwin, I have been using the Gallon Glad ziplock baggie method since I learned it on here. Once I get the oil filter loose enough to unscrew by hand, I slip the glad baggie on the filter and none ever gets out of the baggie, even tipping the filter. It goes into the bag.
I've use the gallon ziplock bag, the issue is to get to it to loosen it! It's like they didn't care how you got the filter loose or out of its cubby hole in the engine bay. I removed the turbo inlet on my old 97 to change it, just one more hose to disconnect on the 2013 than the 97 had I guess? On my 03, I could actually loosen it from underneath and then bag and remove it from above. Such is progress, so they tell me.
See post #3 the frame cross members were changed for the 3500's in 2013. No longer can you even see the oil filter from underneath. I'll post a picture soon of what you see from under my truck. Ken irwin
I have a 2013 2500 and the oil filter IS accessible from underneath.
Here's what the 3500 frame looks like:
Bottom
Side
As you can see, there's a significant piece of steel in the way now, with only a little draining hold for all the oil they expect you to spill. And the side access is not all that great either, I'm not seeing how you can tilt the filter out of there without making a big mess. So from the top it will be in my case. Also, the tube you see in the middle of my engine is the fuel drain tube. I ripped off the original tube and replaced it with longer vinyl tubing and found a nice place to use some velcro tape to keep it out of the way when I'm not draining anything. Sure keeps things neater, much better than draining over the front cross member... I still wonder what the engineers were thinking.
