2014 3500 auto-level rear air suspension system
Problems after changing trailer brakes
black tank is plug.
Does anyone know when this option will be available to be ordered. In tow mode, brings the truck level, front to rear. Want to order truck, but really want this option.
It brings the rear down or brings the rear up? I've never had to deflate my air bags, only air them up to shift weight back to the steer axle.
I want to know if you can adjust the ride height manually? I have a lot of questions before ordering. Will probably wait for the 15's to come out.
This option is not available yet to order. It is in the brochure as late available. It is an auto level system, not manual level. functions in tow mode.
I was told when I ordered my 14' that it would be available late in the model year, but the kicker was that it wasn't going to be available on the max tow equipped trucks. So if your looking
for the high tow ratings it doesn't sound good.
I think the design we saw in drawings, is going to be a bust. Air bags are way to far inboard on the axles. Tommy tippy! I could see them limit it to the lower tow ratings and state no truck campers. I liken it lifting a barbell with your hands close together vs spread out. You can lift it but it will be hard to handle. Snoking
Anyone got any shock upgrade suggestions for 15 lwb factory air bags 2500 with 4 link rear suspension?
brand and type looked at genos want the right ones
please advise
karlb
i went with Fox shocks on factory air rear suspension seems to be a lot better than OEM , had 2 with blown seals leaking probally from fifth wheel tow ?
What truck are you referring to?
2015 2500 srw longhorn longbox 4x4 Auto B&W hitch with factory air ride 4 link suspension apparently shock listings for this truck r nonexistant fox was the only comp that would say they fit
bilstein from genos wouldnt say it was listed as a compatable application , i had read different ,
fox shocks cost more ,
