Evic message said no oil pressure. Stopped truck and checked oil and it was full. All filters are new. Started truck and the message went away. Oil pressure is within specs. Could this be a bad oil sensor?
If the failure tripped a code it will have stored freeze frame data
Most oil filter failures spit a chunk into a cooling nozzle an take out a piston.When that happens you will know with a knock that will scare the stuff out of you
