AH64ID
Can you give provide the steps in the AlphaOBD to initiate the dresoot? Thanks!
Connect to the Engine module, then under advanced options you will see the stationary desoot option. Hit start. Your RPM's will just to ~1000 and you'll hear the exhaust brake close. Within 5 minutes you shout see the DPF temp start to increase to ~1000°F. Both the ones I have done have lasted 60 minutes, to the second.
I go for a drive to get the coolant hot first. I will also monitor ECT and if it's staying too hot I'll spray the radiator with water. I think the last ECM update changed the fan programming during a desoot since it never got above 210° whereas last time I did it the ECT got to 219°. Similar ambient conditions.
It's recommended to drop the spare but I didn't. An IR temp gun only showed the tire a little above 100°F.
