I found a 2016 3500 with only 26,000 miles on it. When I crawled under to look at the underside there was transmission fluid all over the transmission pan. Would the gasket be toast already at 26,000 miles? An older couple owns it and it was pretty much just used for 5th wheel towing. It doesn't have the Aisin. Any info or suggestions are greatly appreciated.
thank you
thank you
