2019 Ram Chassis Cab
- G.R. Whale
At the Chicago Auto Show today Ram introduced the 2019 Chassis Cab trucks. They will be offered as regular or Crew Cab in Tradesman and SLT trim, plus Laramie and Limited Crew Cab, on one of six wheelbases (143.5 to 204.4 inches)—eight if you include the inch difference between 3500 and 4500/5500 60- and 84-inch CA trucks. Unique to Ram is a Class 2 10,000 GVW Chassis Cab.
All the styling, powertrain and interior updates applied to the HD are included here, from the tablet-size Uconnect to grille shutters, and the top trims now come with color matched front fender flares. Apparently this is a big deal in medium-duties though I shouldn’t be surprised now that work rigs have heated and ventilated seats. I’m wagering this will be the quietest inline-diesel-engine commercial vehicle any of us have been in.
For CC the diesel is rated 360 horsepower at 2800rpm and 800 lb-ft at 1800rpm, paired to the updated AS69RC. The 3500’s 6.4 Hemi is the same 410/429 as the pickups, with the 8HP75 eight-speed auto, and the 4500/5500 gets 370hp and the AS66RC six-speed. Axle ratios are 3.73:1 or 4.10:1 on 3500, 4.10:1 and 4.44:1 diesel with 4.89:1 optional on gas 4500, and 4.44:1 or 4.89:1 on all 5500 setups. Alternators include single 180A and 220A units, or duals for 380A or 440A, while fuel is carried in a 52-gallon rear tank, 22-gallon midship, or the combination of both.
Features and options parallel trims much as you’d expect, some of it adjusted for the no-box configuration, such as the surround view camera that’s only 270 degrees. Lane departure warning, automatic emergency braking with trailer brakes, adaptive steering and adaptive cruise control/forward collision warning are available on Tradesman, but all-around or cargo cameras, trailer tire pressure monitoring and trailer reverse guidance require SLT or better.
So how big can your new fifth-wheel or hot-shot rig be? With a single-rear Crew Cab 4x4 19,980 pounds; 25,130 for a dually. Those trucks’ rear GAWR leave about 4100 pounds and 5200, respectively, for pin weight, neither of which exceeds the total payload rating.
On the 4500 peak tow for a Crew 4WD 60-inch CA is 28,770 pounds. Take off about 90 pounds for the 84-inch CA and about 400 for 4WD. The towing charts list 5500 4WD diesel as regular cab only, with tow ratings from 34,450-34,800 pounds. A Crew 2WD, 60- or 84-inch CA only, falls in a similar window, while the short-wheelbase regular cab is the braggart at 35,200. Diesel GCWR runs from 27,500 on single-rear trucks to 43,000 on Max Tow 5500. Bring on the CDL!
The spec war continues. GM is likely to post a tow rating topping 35,000 pounds with a GCWR more than 43,000 and Ford will have their own announcement at Chicago. GM’s pickup has a new 6.6-liter gasoline V-8 and a ten-speed transmission they call Allison, but it isn’t built by Allison—the only way to get a real Allison from GM is in the 45005500/6500 medium-duty all built on the same frame. Meanwhile Ford, also adding a 10-speed, continues saying that competitors have to use an outsider engine or transmission and only they build both in-house, apparently not getting the “Allison-branded” memo yet.
In a world where assembly plants bolt together items from myriad suppliers all you need is a decent “vehicle integration engineer”—the guy or gal who makes everything cooperate in the truck—to make it work. If Ram chooses to let Cummins and Aisin spend the development dollars so be it, and you have to wonder if in-house is always best, why are so there so many B engines in trucks, busses, motorhomes and boats around the world?
The only question left is what will be the next benchmark? A 40,000-pound tow rating? 1100 or 1500 lb-ft? 500 horsepower? $125,000 fully optioned? I’m about ready to go shopping for a used Hardbody or Tacoma.
Thanks for the update. interesting the C&C with 6.7L Cummins rating is the same as the 6.7L Cummins in the RVs at 360 HP and 800 Lb Ft of TQ. It's great that Ram and Cummins are growing/improving their entire truck line.
Cheers, Ron
Friends,
2017 Must have been the last year FCA installed radio antenna masts on Rams. My wife's 2019 doesn't have it and when I was browsing in the 2018 C&C build and price site, it mentioned radio mast N/A. I recall reading where folks were complaining about bad AM/FM reception, so eliminating the mast may be the reason. And no eight track or cassette offered either. Doh!
Cheers, Ron
Friends,
Cheers, Ron
I won't be able to play my Ink Spots eight-track?!
Nope, unless we want to do some "custom" work on your truck. I feel terrible I got rid of my eight tracks... had some good ones but player crapped out. Still have lots of vinyl and cassettes, and play both from time to time.
I saw a 4500 Tradesman crewcab, 84" CA at a dealer the other day. It was pre-sold and waiting for upfit. Interestingly, I was told the order window for 2019 C&Cs would be closing "in a couple weeks", and the 2020 order window would not open until some time in October. What? With the late introduction, they just started shipping didn't they? They sure made a mess of this model year, IMHO. If what I was told is true.
Dodge and Ram were/are notorious about late/mid year releases. And they always seem to separate the new model 1500s and HDs by a year apart.
All fun. Cheers, Ron
I would like to have seen the 8 speed come out in the 19 RAM, I would imagine it will certainly come out in the 5th Gen. 1,000 lb/ft of torque is plenty, an 8 speed would raise the GCWR even more and be more than I would ever need. Not excited to see the price though..
There is a loaded 2019 3500 Limited 4x4 a few cents shy of $80K at a dealer near me. If it weren't for a little problem with my ankle, I'd go see it. The window sticker online prominently has 1000 lb ft tq by the 6.7L Cummins tag in the upper left corner.
Correction, it's a Larramie Longhorn. and dealer is discounting it almost $7K.
Cheers, Ron
The 2019 5500 we looked at did not give me goose bumps. Install a newly designed 8-10 speed auto and up HP/TQ ratings to newest levels them I might shiver.
Friends,
Here's a nice one at Bluebonnet Ram in New Braunfels: Same sticker price with bed as my 2017. Sweet!
I have mine at the dealer to work a software solution to enable grid line feature on my back up camera. I understand FCA issue that aftermarket body outfitter doesn't center and get correct height on it, that there is potential liability backing into something. Mine is centered and the correct range of height. Backing, especially to hook up pull behind trailer so much more effort without grid line reference. I paid for it and want it to be fully functional. My dealers really good at working these type of issues.
And, getting it fixed while I'm laid up is no down time for the truck.
Cheers, Ron
