2020-2023 RAM 1500 EcoDiesel Transmission Fluid Flush/Drain Pan Replacement
New EcoDiesel Owner/TDR Member
PO20EE Dpf efficiency code
Diesel85
Here's a short video of what needs to be done to change the transmission fluid in the 2020-2023 M/Y EcoDiesel RAM 1500 truck.
In the video I explain which fill plug to use, some suggestions, how to make a BIG mess (no, really!), and what to expect in regards to fluid color/composition from a truck that has 52,000+ miles on it. Also, pardon my videography skills in this one, I was a bit frustrated that I was literally covered in transmission fluid.
All parts I used are Mopar parts, that includes the fluid and pan (with the included gaskets, screws, and fill plug). I also show the torque specs, and ALLDATA diy information that I printed out. You can pause the video to read the procedures and study the pictures.
This instruction is only for RAM 1500 DT model years 2020 through 2023 with the ZF 8HP75 on the RAM EcoDiesel 3.0 Turbo Diesel Engine.
Parts:
  • Total fluids needed: 8.5 US Quarts of Mopar 8&9 Speed Automatic Transmission Fluid -- (I'd recommend just getting 10 bottles) - Mopar Part#: 68218925AB
  • Mopar Transmission Pan (comes with pan gasket, integrated filter and magnets, suction side o-ring, drain plug, 13 mounting bolts, and new fill plug with gasket) -- Mopar Part#: 68225344AA
Tools needed:
  • Eye protection, disposable gloves, oil waste container, lint-free towels, and spill response kit.
  • Level garage lift, or floor jack with jack stands for safety.
  • Torpedo Level (To level the transmission and truck)
  • Appropriate torque wrenches (small (in-lbs) and medium (ft-lbs)
  • T40 Torx bit (to remove/install the 13 pan bolts)
  • 8 mm Hex bit (to remove/install the fill plug)
  • 10 mm Hex bit (to remove/install drain plug)
  • Fluid Pump for Quart sized bottles.
Jack up the truck and make sure the truck and transmission is level (critical). Drain the fluid, take the pan off, then pop the new pan back on. Refill, start the truck and wait a few minutes, run it through the gears, get it to 2nd gear, then wait until it gets to about 90F, with the trucking running, then top it off until a steady stream of fluid comes out. Then lower it, go for a test drive. I went ahead and double checked my work, and found that the next day it needed about 15 mL more fluid (3x pumps worth). I think it's from the new filter absorbing the new fluid.
I hope this helps the new owners, as there are plenty of videos on the older models where you drain the transmission from the right/passenger side. The 2020-2023, the DPF is way too close to the fill plug as shown in the video. The correct fill plug on the EcoDiesel 2020-2023 is on the driver's side, which gives ample room to work.
I did find that getting the fluid back in is quite the process go slow, or make the little adapter like I did out of the old fill plug. But be warned -- check it every so often so you don't waste fluid like I did!
Enjoy!
