215 HP OR 300 HP INJECTOR'S? 300-350 HP GOAL.
That "dog" won't pull anymore!
Any benefit from a cooler thermostat?
As soon as i do some trans mod's i'm gona start turning her up a bit, my goal is 300-350 hp. hear my wish list as of now. #6 plate,4 in exz & some injectors but not sure which ones. i seldom tow and when i do it's never over 9000 lb. i don't want to change the turbo housing & i don't want a lot's of smoke (little ok). will EGT be a problem at this power level? last guestion. will this put me in this power range?
95 club cab auto 2wd +GENO'S COMBO GAUGE + SONY 10 disc + RCA 9" tv/vcr + 1 CHAMBER FLOWMASTER +LOST cat + silencer ring + slid stock plate & k&N so far... ! member of the SETDR
215s shouldn't have much of a smoke problem, especially if you also install an AFC spring kit. You might want to consider 370s instead of the 300s. If I remember correctly, Joe D. did not recommend the 300s. Joe, please correct me if I misquoted you. If you use the 370s and have the 160hp pump, you will probably need to change delivery valves.
1996 3500 Clubcab SLT, auto, 4. 10 limited-slip, TST #5, 370s, AFC spring kit, Psychotty, Dunrite converter, Trans-Go, Walker 21471, DiPricol EGT, boost & trans temp. gauges, 9 ft. aluminum flatbed and tool boxes with Venco dump. Custom front bumper, Hadley air horn, PowerVision mirrors.
Correct, Koa Man. 215s plus the strong TST plate should get you to 300+, even with a 160 hp. 370s will give more but the transmission becomes a problem around 250 hp; be sure it is upgraded well. EGT becomes a problem around 270 hp. For the goal of over 300, a 16 cm2 housing will be needed, backed up with low restriction 3" exhasut system. 4" won't help appreciably until you go for the HX40.
Yep, sure would. That is, if help=more power #ad
215s are expensive new. Occasionally I get used ones in trade. I also get ones that are low mileage, cleaned and balanced by the Bosch shop. Less pricey. Check around and see what you can find. No one wants less power #ad
