Competition 225 PSI out of twins.
Competition Link to Will Fletcher's article!
Competition DHRA Sled Pulling email list.
95 ext cab , fresh motor, 14mm studs,billet roller cam,filled block& redesigned head,dry sumped & vacuum pumped, . 080 over forged pis. ,HT60/HC5,225psi, triple disk clutch, not enough room for the rest... but when it hits 6K hold on.
Anyone else read this sig?:cool:
Puller or dragger?
Puller or dragger?
Are those Don M studs ?
I've seen the sig, but not not the truck. Surely someone who spent the time and money on this would want to put it to work??
Puller or dragger?
Dangit anyhow Gene... . i told you not to tell anyone about my "fresh" ride:eek:
Don has said he can get anything made for you if you order it, but right now I believe he's only got 12mm studs in stock. I think Haisley is the only one with 14mm studs in stock right now. I'm sure someone will correct me if I'm wrong...
Chris
This got me thinking!
This truck either has HUGE intercoolers, or uses more water than fuel. The water wopuld have to be injected between the turbos and in the inlet plenum.
If not, turbo discharge temps are in excess of 1000F :eek:
GO 4LO:
Scheid Diesel also stocks the 14mm studs. In fact, I believe
Haisley Machine gets their 14mm studs from Scheid but I could
be wrong about that.
To order a set of the 14mm studs from Scheid Diesel, members
can call Kent Crowder @ Scheid Diesel (Lafayette, Ind. ) @
1-800-669-3533.
John_P
Originally posted by John_P
GO 4LO:
Thanks for the correction!
Chris
Yup those intercooler boots (turbo side) and hose going into turbo inlet better be able to take some HIGH temps. Don't even use those POS silicon boots. Bought a set of them and had the turbo inlet boot blow out the first week and the turbo side intercooler boot blow out 2 weeks later. I still can't believe it'll hold 225 lbs of boost-damn it's gotta be like sex... ... ... ... I think but I can't remember back that far. :D
