I have a Keystone Raptor that has 7,000 axles under it. I need a GOOD QUALITY 235-85 16 tire that will hold up to the advertized 14,000 lb rating (minimum 3500 lbs per tire).
It came with Power King 235-85 16 tires that are rated over 3500 lbs each however I've separated 3 already in less than 4,000 miles with the last one shredding when I had TWO separate and ruining an aluminum wheel in the process.
None of the name brand tires are made with this rating that I can find but there are a bunch of specialty brands. LT tires do not have the required load capacity in this size.
I did check the Powerkings out on the NHTSA site and found these tires are an issue on the heavier rigs.
It seems that any trip over 200 miles is a problem. I tow at 55~60 MPH.
Ideas? I see several manufactures who make a load range F in this size. Would that help?
Thanks,
PS as soon as it has wheels under it again It's going to the scales to make sure it is under 14,000 lbs at the axles.
Thanks,
