235's in place of 215's???
Guages, Do you really need them?
Fuel filter changing
Guys,
I have a 99 3500 cab and chassis. It has 215's on it from the factory. I noticed the new 2000/2001 duallies come from the factory with 235's. Can I put 235's on my truck when I buy tires without fear of them rubbing???? Say if I go with 235/85's will I need to have the speedo recalibrated??? If so how is this done??? Can the dealer do it???
thanks
Don
Ol' Blue "First of the first gens: 1989 D 250 Ice blue met. 5 spd 3. 54, 155,000, Banks stage III powerpack, 3. 5" straight exhaust, pump adjustments, "'Ol Blue Special" injectors.
1999 3500 4x4 Chassis cab Emerald green ISB 5 spd 4. 10 K&N Filter straight exhaust 9 ft flatbed WARN fenderflares,Let, 275hp injectors installed, boost and pyro gages, VA plug'n power and Practical Solutions boost module. Jacobs E brake. Getting ready to install Banks Power Pack TLC!!
May buy another one in 2009!!
Check my signiture. Yes you can. Be sure you get an E rated tire and compare section widths of a few brands. Also search the archives.
As for the speedo. I think you will need to add an electronic device to correct. Again, check the archives.
'94 3500 4x4, 205,000 miles, Never had a cat, Auto w/shift kit (thanks Dave G), 3. 54 Gears, TST #5 plate, 235-85-16s, Rancho 9000s w/remote, Isspro gauges inplace of cupholder & Amsoil Air Filter & Lubes, AWOL silencer ring & intake boot. NRA member. Blue Ribbon Coalition member.
"Warrantee? We don't need no stinking warrantee!"
I plan on running Michelen 235 85 r16's always buy load range E tires.
thanks
Don
