fuel oil
Hello
I think the problem is info is to much to take in .
We all need to stop and think what we are trying to do
Yes the cr motors are a pain but they will run on blend fuel I have two trust me
Yes the older motors will run on about anything this is what I have been told
the problem is I dont have an older motor I have two cr engines an 2004 and a 2005 555/610 the 04 loves the blend fuel the 05 hates it you tell me why ??
I think its the 3rd event in the fueling plus the fact that the 05 was a cat on it . I have to play with the cr engines (ie run what you brung)
The heat is an issue this is a problem but what I am saying is that you dont need to heat it to 170 degs you need to thin it out but that's it. 100/125 degs should be fine.
I have run my truck on dse blend fuel for about 7 months , the only problems is with the fuel filters pluging in the cold (this is why i think heating the fuel will help) also its a will known fact that heated fuel will burn better ask any real trucker (not the ones that just drive the truck's ask the ones that drive and fix there trucks)I have they told me I need to heat my fuel
No, I am not saying that dse fuel is the end of the earth ,there are many other things that need to be tryed
we need to try anything that makes sence, bio/synfuel/used motor oil/ veg oil/used veg oil /whatever might work we need to try!!!
my plans is to heat my fuel to 100/125 degs
run a blend fuel of used veg oil/kerosine/gasoline/and dse fuel additive
if I kill off my injection pump /will live and learn.
if it works I will tell everybody/that it works or if it does not work !!!
If I made you made I am sorry but we can't sit here and hope the oil companys help us out they wont they dont care !!!!!
I just came back from Longbeach Ca the going price for #2 was 3. 199 per gallon I did see if for 3. 099 to 3. 399 per gallon if its there its going to get that high everywhere I THINK WE ARE HEADED FOR A LEAST 4. 00 PER GALLON BY THE END OF SUMMER . THIRTY GALLONS OF FUEL WILL COST YOU 120. 00 DOLLARS
read this its good
http://www.frybrid.com/vp44.htm
cj hall
