Is bio safe for a 2002 ctd? We have filtered it with methanol/lye mix and water wash is it now safe?
Thank's
Thank's
GWedekind said:I have run WVO veggie for 2 years on my 99 dually. In the last 12 months/ 40,000 miles I have had 4 injection pumps go bad ( that includes the original pump ).
I have tried heating the oil on the first 3 pumps running 100% veggie and then tried unheated 75/25 mix ( veggie/diesel ) for about 6 months and just popped another pump.
I believe the module on the top of the VP44 went bad on at least 2 if not 3 of the failures I had.
Part of me thinks that the module is getting hurt by using an agressive mix of WVO but without knowing how the pump works its hard to tell.
I am considering the biodiesel method where you mix alcohol and lye to get the WVO cleaner and MAYBE it will run better and be less harmful to the VP44.
My opinion... get a truck that doesnt have a VP44 if you want to run WVO . Im getting tired of changing pumps and getting stuck many miles from home.
6naline01 said:I am considering investing in the fuel meister from bio-solutions looking for some input. Thanks in advance 6Naline01
DSiemens said:Having only been reading, B100 reported works fine in the P7100 and 03/04 CR systems. It's unclear in 05/06 CR units. What reports do we have on VE and VP44 units? I suspect B20 works fine in all units as it's being sold but maybe someone has an experience they can share.
