24v timing
Re-drilling/Re-tapping hole for larger size.
battery hold down
Just was wondering if anyone had an idea of the amount of timing I would be at with a comp drag and a MAD ECM.
Thanks in advance.
From what I have been hearing, that combo should put you in the 23*+ area, depending on flash of the comp, and the tpye of programming of the ECM.
Marco does a Special MAD for the comp. I'm not sure if it adds anything at wot as far as timing is concerned. Ask the question on the Catcher/MAD post and see what Marco says.
