Engine/Transmission (1998.5 - 2002) 24v timing
2nd Gen Non-Engine/Transmission truck for sale
Engine/Transmission (1998.5 - 2002) Transfer Case Tools
Just was wondering if anyone had an idea of the amount of timing I would be at with a comp drag and a MAD ECM.
Thanks in advance.
It is controlled by the ECM. It is not static timed like the 12v engnies. The computer adjusts the timing based on the parameters in the programming.
Thanks in advance.
Both advance timing & together it can be to much. The MAD CaTCHER uses about the optimal timing, so if you intend to run it with a Com. , you should order the CaTCHER referred to as the special which is designed for use with the Comp. Sorry I can't give you specific numbers as I belive they are generally considered trade secrets.
