<b>Welcome!</b>
For what its worth: You can swap around anything but it sounds like you may not really need to if you put 100K w/o any probs. I am not sure what rears are like on these dodges but a lot of times there are narrow ones and wide ones. You will have to at a minimum put in new studs (longer) and most likely have to have narrow tires. The benefit would only add in a few inches of width, so it is not really worth it. You could widen the rear, but that can cost some bucks. You may want to try a 12-16. 5 tire, heavyest duty version (they varry a little). Best benefit of a dually is usually stability rather than payload, by having it much wider, which drasticly helps. I have a
project that utilizes a dually in place of a single setup, and the tires fit perfectly, axle and body stock (but narrow type rear), so I am not going to rule the possibility out, but for you I would get a dually or widen yours for the stability towing 22K+ - you will appreciate a more stable platform.
As for the front, a lot of times it is only an offset hub assembly which can be put on in your case, but I am not sure if your rig is 2 or 4 wheel drive. You do not have to have the offset frontend when you run dually rears, you just would have 2 different rims so that means an extra spare.
This is more for towing type of setup, if you do pulls (assuming competition stuff) I could not help you there 'cause I do not do any kind of that stuff.
