so I am looking at 2 trucks to buy. one is a 2500 the other is a 3500. all options the same. but why a difference in tow rating?
TowPro said:I put new overload spring perch rubber on mine that is around 2" larger. No difference in the ride unloaded, and it sits level with my 5th hooked up where before it used to drop around 2"...
TowPro said:... Plus I hear the 3500 SRW rides better then the 2500 because the main spring is softer. Then can make it softer because the overload springs kick in when you load the truck.
JJPage said:My Insurance man was very happy I purchased a 3500, $$$$$ he could charge me for premiums. Also in Washington State they love you for your available payload capacity when licensing your rig
Just something else to consider.
fkovalski said:I take you mean taller bump stops such that the overloads are engaged sooner... ? Which one did you use? Was it from Energy Suspesion?
Also- Can the 'constant' engagement of taller bump stops rub against the overloads (when loaded) to where it rubs the rubber constantly? (hence... wearing down however minimal over time. . ?) I have read where this may be a concern.
I almost would rather have a constant rate true 1 ton suspension (like the ole' days) rather than that of a progressive rate "2500 into 3500"...
I do not think this is true (but I could be wrong. )
TAbbott said:They're the same axles -- same everything except for the rating plate and the insignia -- if they're single rear wheel except for the overload springs that come standard on the 3500. And you have to remove the overloads if you want to install air bags.
