I pull a 9000# 5th wheel, extended pin box with my shortbed quad cab 2wd. My hitch weight is 1880lbs, the pin is directly centered on the axle and the truck is about 1" above level in the rear and just touching the front pad on the camper spring. Rear axle weight is 4960lbs and the truck rides and handles fine. With the hitch in the forward location I have never had to slide it to manuver, although if you ever wanted to jacknife completly, you would have to slide it to get cab clearence. The one problem you will have is the height of the bed rails. You will probably have to flip the axles under the springs on the trailer to get the needed clearence, and beware that all trailers won't allow you to do this. Good towing.
01 2500,SB, Club Cab, 5spd,3. 54 LS, Bright White, Camel Leather. 01 Sunnybrook 27' 5ver--All Stock
