27 lbs of boost on a near stocker?
steering gear box and auto transmission
my turbo seems to WHINE more ok?
OK, I've moved the diaphragm and turned the max pressure screw one turn.
On the dyno, I was pushing 27 lbs of boost. I believe the turbine housing and injectors are stock. Does this sound right?
I recently straight piped it too. When I slipped in the boost gauge from my hot rod, I get 23 psi in second gear, 25 in third, and 27 in OD unloaded.
I thought the pressure would be lower.
I guess I should mention that it's a '92 D250 club cab automatic. 3. 54s out back.
[This message has been edited by feets (edited 04-21-2001). ]
Sounds a bit on the high side for as near stock as yours is - perhaps the guage is reading a bit high?
My early '91 ran about 22 lbs max before I installed the Banks stuff listed in my sig - I have turned up my pump a bit also, and the intercooler installation reduced max boost to right about 20 lbs max...
http://community. webshots.com/user/davison71 Early '91 250, 727 AT, 307 rear... Banks Stinger exhaust, intercooler... US Gear OD... Tweaked pump, upgraded radiator... MORE than a match for every new PS Ford encountered so far...
"Dura" WHAT? NOW I know where all those recycled beer cans go...
