275 Injectors & EZ Dyno results
wastegate - and boost pressure
Too Late To BOMB???
Just had 275(scheid diesels version) injectors & EZ installed and thought I would share my dyno results, this is on a 2001 HO 6spd. Stock-203HP 506Ft lbs. -Injectors-250HP 628Ft lbs. EZ with boost elbow and injectors 300HP 840Ft lbs. EGTs post turbo after injectors 1050-1100 after EZ/elbow (boost now 26-28 lbs) 950deg.
Finally this truck will pull... ... ... . IF I can keep the clutch in it.
I noticed tonight 1st time after mods pulling my 12000# fifth wheel that the truck seems to surge(for the lack of a better term) around 54-56mph 1700rpm in high gear no cruise control, if I bring the rpm up it goes away, any Ideas ? can these have to much timing ? it only does it loaded not empty.
Chris Wilson
My pickup does the same **** surging, and it did it stock so I don't think it's the mods. My dealer can't find anything, let me know if you find something out.
2001 Quad Cab Dually, ETH, SLT Plus, 275 injectors, Banks Power Pack half way in.
please post your dyno chart i would like to see the torque and horspower curves. what kind of dyno was it.
2001 eth, ez box, dd2's
RV injectors and EZ box adding 100 ponies? #ad
Who says the ETH doesn't wake up with a set of RV injectors and a good box???
I tried CUMMINNTSTRKN's EZ box on my ETH last weekend (which has RV injectors) and liked the considerable power gains, woke the Cummins right up #ad
I didn't watch EGTs too close but don't think they were much higher than without the box.
It is nice to see ETHs respond well to boxes. I also tried Bob Wagner's old van Aaken, it worked awesome and helped deliver a 9 second 0-60 with 400+ lbs of sand in the bed. EGTs maxed at 1050 on a hard 0-90 run (in a 35mph zone #ad
) Cdaleh and some others tried the van Aaken at the NW BOMBer bash as well. With the vA on he spun the clutch of his RV injectored ETH #ad
Jim, how are you liking your Stage 2s? Any affect on mileage?
Vaughn
'01 2500 QC Shortbed 2wd, 6-speed, 3. 54LSD, Cab & Fog lamps, Camper & Tow Pkg.
BOMBed: RV injectors, PS Boost module, Amsoil air filter, straightpiped exh. , Aeroquip 3/8" fuel line w/tank mounted lift pump, AutoMeter Sport Comp gauges, Line-X'd, Amber turn signal conversion.
Mildly BOMBed Performance: 0-60 @ 10. 0 sec. ,
40-60 @ 5. 5 sec. ,
0-100 @ 24 sec.
[This message has been edited by Vaughn MacKenzie (edited 02-23-2001). ]
i like the dd2's. as far as mileage i got almost 19 going to nw bombfest with no cruise. and coming back i got almost 18 with the cruise at about 75mph. the cruise isn't very smooth since the 2's.
jim
Jim, you were gaining more altitude heading east (home... Helena, MT) then you were heading west to Rob's (Enumclaw, WA).
john
i didn't check my mileage to cleellum (sp. ) thats were i filled up and i got almost 18 from there to helena.
jim
[This message has been edited by CUMINNTSTRKN (edited 02-23-2001). ]
CUMMINNTSTRKN:
The dynamometer that "Scheid Diesel"
uses is the "Mustang" Dyno. They dynoed
my truck at their rally last year.
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit,Psychotty Air Filter, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
Good to see an ETH can respond so well! Seem's these have potential dispite earlier assumtions of not being cabable. Just one question though; Dynoed 506ft lbs Stock? They're only rated 505 at the flywheel stock!?
2001. 5 2500 ETH SLT QC SB 3. 54 Hd 241 Camper, tow,
Cuminntstrkn, There Dyno is a Mustang, I would be glad to post my dyno print outs if someone more computer literate than myself can tell me how to... ..... got the scanner... no no how.
2001 3500 4wd H/O 6spd
So Papa,you thinking of coming out a day early for Dyno Day again to do a little BOMBing? Hehe! #ad
Did you ever get your 275's back?
-Mike
[This message has been edited by MikeR (edited 02-24-2001). ]
Insurance company wouldn't let me get 'into the engine' for the injectors. Had I been healthy I would have done it anyway, but such is life. I got the PS Module, but it won't fit the ETH. Psst, it's for sale.
275s and the EZ are sounding like a lot of bang for the buck for the HO, Mike. I'm going to lay quietly in the weeds like a snake and listen for awhile #ad
Papa Joe,
Cumminntstrkn put in DDII's and an EZ and Dynoed at 391 HP and 822 ft/lbs of torque. How about going to the DDI's or DDII's?
Don't forget you gotta keep ahead of the Duramax of your partners! HeHeHe #ad
those numbers sound a bit high I am running dd3's, ez psa hx40 and not getting those numbers just my. 02
2001. 5 ETH/DEE 4x4, DRW QC DD3's, EZ, HX40 machined out for more flow, Custom 4" exhaust turbo back staight pipe with 5" chrome tip in front of rear tires,spa's, mcleod clutch, fuel lines,mag hytech rear end cover,psycotty air system,relocated blow by bottle,Lucerix power heated mirrors,more to come
275s and an EZ..... 100 hp increase on a Mustang Dyno...
Hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm... ... Gotta go, the wife's calling #ad
Shhhh !
Originally posted by Papa Joe:
I got the PS Module, but it won't fit the ETH. Psst, it's for sale. #ad
Papa Joe, I emailed you off line Yesterday #ad
, tell me if you did not get it #ad
TowPro
  • 98 ISB,QC,5spd,2wd,3:54lsd. Stock with BD brake and Gauges!
  • 2000 Terry 305G 5th wheel
[This message has been edited by TowPro (edited 02-25-2001). ]
Stupid newbie questions.
What's the boost elbow, where does it go in relation to say the turbo and an exhaust brake (leaning toward the Pacbrake right now).
Pepee' (My little Mule)
2001 HO, 3. 54 rear gears Forest Green Quad Cab
Ordered 2/5/01
[/b]
Windrider... IMSWHO. The only stupid question is one not asked! #ad
The boost elbow goes on your turbo to change how your wastegate operates. . they increase your boost pressures. . usually lowering smoke levels and your EGT's (exhaust gas temperatures)it must be used with a boost module so your ECM (engine control module) will not cut back fuel and set a overboost error code in the computer. . Most new POWER boxes (PowerEdge EZ is a great one) include both with great instructions that make it easy to install.
It should not effect your exhaust brake.
For more information it is a good idea to start a new Question/Topic. . You will get "KWIK" help and you can have Email notification that someone has applied to your Topic.
Also at the top of each page there is a search feature. . Works great. . Try searching ,Boost Elbows, PE EZ, HVAC ETC.
"Have you driven OVER a phord lately"
2001 2500 BRT WHT SPORT QUADCAB 4X4 ETH 3. 54LSD TRLR CMPR PKG ALL OPT XCPT LTHR
[This message has been edited by KWIKKURT (edited 02-27-2001). ]
