275s+ez=?EGT
Oh Boy-My First Check Engine Light
Post turbo oil temp guage?
The warrantee is gone and the credit card is out. I just ordered a DTT vb and tc, SPA gauges, 275 injectors and a PE ez. The question of the day is what EGTs will I see with this? The truck has about 10,000lbs of trailer behind it about 40% of the time. I would like to hold off on a 4" exhaust if possible to keep the sound down. BTW, thanks to all who post, this is the best sorce of info out there bar none.
99 QC LWB Auto ETC 4x4 3. 54 gears, 265 tires, Lear cap, IAS shocks
oldiron,
With the EZ and 275's, you should have no problem with EGT's as long as you install the boost elbow along with the EZ. With 10,000 lbs. in tow, I am hard pressed to exceed 1,100 deg. pre turbo. Although I do have a 4" exhaust. Although this combo does not seem to create EGT probs. , I wouldn't do any upgrades without gagues - its just good practice. Hope this answers your question.
Craig
2000, 2500,QC,4x4,white,tow,leather,6 spd,4. 10, 4" exhaust - turbo back, K&N, Balls of steel hitch, line-x bedliner, Autometer Ultralite pyro and boost, Mag Hytec on Dana 80... wouldn't dare add anything to void that good ole DC warranty!
I am running the eact combo that your are investigating and I tow with 14k on the back and have no EGT issues, if I turn on the PE box level one still no issues unless I just flat out nail it but I do not recomend that unless you realy need it during towing. You will love the combo it adds a nice round power vs egt setup.
TAZ... 2001 2500 SLT+ 4X4 Auto ETC Cummins, LSD 3. 54,Quad Cab, Long Bed, Agate Leather, White/Driftwood Exterior, Sliding rear window, Camper Special Group, Towing Group, Cab clearance lights,SPA-Technique Digital Dual Gauges (Pyro/Boost, Trans pressure/temp) Aux. Backup lamps. BNM 5th Wheel Hitch, Additional Body Molding on Bed. Line-X bed-liner. DTT's TC & VB, Pac Brake, Power Edge, Edge EZ, Grover Air Horns
2000 32' Aljo Triple Slide 5th Wheel.
http://www.ramtaz.com
Add on's to come: any other Ram Runner required modifications...
Alright, already! I give up! After following these threads for months, I am forced to ask an embarrassing question--
What is a boost elbow?
I feel so ashamed already... . I'll be hiding woefully under my truck awaiting answers
No such thing as a stupid ?
A boost elbow is a little brass pipe elbow fitting that fits into the compressor housing on your turbo, if it's not an HY-35.
This fitting makes the wastegate blow off at a higher pressure as opposed to lower pressure, therefore more boost.
As for how it does this, I don't know.
2001 2500 4x4 ETH/DEE
3. 55 LSD, Stock is all I will be able to afford for a few years.
OldIron, I ran this combination for about 2 months, before switching to DD2's. No problem with EGT's. Good combination, especially with the DTT transmission mods.
Fred Swanson
Co-Owner
Canyon State Components, LLC
www.canyonstatecomponents.com
'00 QC,SB,4x4,Auto,3. 54 w/LSD,Trailer Package, Tow Package, DTT's VB & TC
I have the same stuff, plus a little more. I don't tow much (just a couple of snowmachines) and I have the baby turbo. I do not think you will have any problems other than a permenant grin stuck on your face.
John D. Rathert Jr.
01 2500 Forrest Green Sport SLT+ QC LWB 4x4 Auto 3. 54 rear end with all options avail. DC Nerf Bars, DC Grill Guard, DC mud flaps, Line-X bed liner, Leer 160XL Topper, Power Edge, EZ Edge, SPA Boost/EGT Gauge on pillar mount, DTT's tc/vb combo, 275 RV injectors, DD 4" Exhaust and a KN RE0880 where the air box use to be. New turbo (HX40), SS fuel lines and bigger injectors in planning stages... . See My Truck, Dads truck: 98. 5 3500 SLT QC LWB 4x4, Brother Truck: 92 W250 SLT CC LWB 4x4 (Dads old truck) Winter fun - 2000 Skidoo Summit 700
I am my own warranty station. ZOOM ZOOM
I also have similar mods but different brands with no egt problems but you will find chasing japanese and european sport cars uphill taking up more of your spare time.
'99 QC SB White/Agate Mustang Bed Cover, Bed Liner,BD PNP, 4" ex, 275 injectors, ISSPRO PYRO/BOOST A-Pillar,LOUD JVC CD, boost module and elbow coming soon.
The right 4' exhaust does not have to = LOUD unless you order it to be LOUD. Yes you will need to upgrade the exhaust, either a 4" or by eliminating the stock muffler and straight pipe the gap left by the muffler. ( loud )
I have the JARDINE 4' and at all speeds the engine noise is louder than the exhaust noise.
If you install the transmission mods first you will be able to evaluate the product.
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T, REESE 15k 5th slider, EASLEY BULL BAR, MAAP NERFS, BFG-TA's, 9000's,TORQUS MAXIMUS 505 lbft ECM, stealth DD2's, Bully Dog Boost & elbow, ISSPRO pyro, boost & transmission, Turbo Lifesaver, JARDINE 4", DTT VB,TC,TC SAVER and AUX COOLER, PAC BRAKE, MAG HYTECH TP& DC, AFE filter, GEAR VENDORS OD onboard. Taylor Wing on order
pullees:
#1 y2k ARTIC FOX 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
