285/75/16 load range E tires
Need a stock muffler & tail pipe
New Brakes! (First on a Dodge)
I too have looked for a set of 285's with a load range of E. Les Schwab Tires does not carry them. It is probably our luck they are some sort of specialty tire that cost great gobbs of money. :(
Anybody have an idea or seen a 285 in a 10 ply build. :confused:
most of the time load range d tires are only rated at 40-50 lbs under load range e tires. My LR D tires are rated at 3000 lbs per tire.
if you look many of the load range D tires in larger sizes as rated much higher than a load range E in 245/75, 235/85, or 265/75. I like the stiffer feel of an E range tire but have never found one in a size i will run. i am hoping some one introduces a load range E 285/85 or something like that. Would be a sweet size but does not exist.
i believe the swamper truxus come in a 285/75 16 load range E 10 ply
I have the stock 265 michelins. I love them, but if I remember correctly, they are only 7 ply!?? The plys are posted on the sidewall.
Silver there is a discrepancy in modern tires. It used to be that the number of plys was actually the number of layers of rubber in the side wall. Now it is a rating not an actual count. Your stock michelins are a load range E or 10 ply rating but very well may have seven plys in the side wall. i believe that bias ply tires are listed with the actual ply count but I am not sure of that.
OK I checked them. This is what it says:
Tread: 2 Polyester
+ 3 Steel
Sidewall: 2 Polyester
So I guess load range E does not necessarily mean 10 plys
Thanks for the replies guys. I know that I can get a load range D tire with about the same if not more capacity, but I like the added sidewall stiffness from the load range E tires when I tow. The swamper tires are a bit too aggresive for the truck, although I have a set (not E) on the Jeep and like them for that. I'm looking for more of a street tire that has a M+S type of tread, so the state patrol won't jump me in the mountains without chains.
Tread: 2 Polyester
+ 3 Steel
yes you are correct, most load range e's come in either 8 or 10 plys...
I am looking at Nitto Terragrapplers in LT295/75R16. The load rating on these is 3415@65psi. Has anyone tried this tire on a factory aluminum rim? So far I have them priced at $155 ea, but I think that with a bit more looking around I should be able to better that.
Cummins, how old are your tires. The reason I ask is that I was just in my local Schwab store and they said no dice for a 285 "E" tire. Maybe they discontinued them, or the guy wasn't informed.
Gunner, there are a number of members running that tire at this point and all seem to be having good results. I have had 295/75 BFG ATko on my truck for over 45k miles now. They have been great but next time I am going to try the nittos. They are cheaper and people seem to like them.
Thaks, Ted. Good to hear. All I know for sure is that I would rather run barefoot across a frozen pond than drive on these Michelins in almost any off road condition. I need to stay with a tire that can carry the weight because I tow an 10,800lb gross weight trailer. I don't think that the 295 will crate any roadability problems, and they have got to be better off road.
Thanks for your input and I will post with initial evaluations after they are on. I am going to try to run the Michelins out till about august, but they may not make it.
Bridgestone makes a 285/75/r16 load range D. The tire is a Dueler A/T REVO that has gotten a LOT of good reviews. They make several Duerler series, its the REVO that seems to get a lot of praise.
Tires
When I look at tires, I take note of the load rating (C, D, E, F, G... ), but I pay more attention to weight ratings (what the tire is rated to carry in pounds). True, a higher ply rating will help with punctures, especially sidewall compromises, but how much rock crawling are you doing?
Nitto makes a great all-terrain tire that is designed to be off road tough, come in larger sizes, and be rated to carry heavier loads that other over-size tires can't touch.
LT265/75R16 3000lbs@65psi
LT285/75R16 3305lbs@65psi
LT295/75R16 3415lbs@65psi
LT305/70R16 3525lbs@65psi
LT315/75R16 3195lbs@50psi
LT325/70R16 3195lbs@50psi
For comparison, my factory Michelins (LT265/75R26) are rated to carry 3,415lbs @ 80 psi.
Food for thought? Better ride with the lower pressure, better comformity off-road.
Check out http://www.nittotire.com/mainframe.asp
I think that its going to be the 295's for me. Just don't want to deal with the 305's rubbing or lifting the truck. Still can't believe how much work I have put into this even with all the input from all of you at the TDR.
