SNOKING read all of the threads you posted there the same as the stuff you and YNOT are trying to push a mythical TSB that supposedly causes this problem but no tsb # and no facts to support it. Go to page 8J 26 of the factory manual it explains the operation of the oil pressure gauge in detail if you read it you will find if the pressure is between 8. 5 lbs. and 80 lbs. the gauge reads ACTUAL pressure if below 8 lbs the pcm will take the needle to 0 light the check gauges indicator and sound a chime. If the pressure is over 80 lbs. the pcm wil take the gauge to 7. 4 degrees below the high end of the scale and hold it there until the pressure falls below 80 psi and then will read ACTUAL pressure . The only time the pressure will be over 80 psi is on cold start up do you think knowing your oil pressure is acually 93 psi instead of 80 psi is useful information ? The reason for this is for every increase in the range of a gauging system there is a corresponding decrease in accuracy . Think of it this way a yardstick has a much larger measurement range than a micrometer but is much lesss accurate . Thats an extreme case but I hope it makes the point. I hope this clears things up some on this gauge issue.
