Everyone,
To start I have read 100's of posts and spent the last 2 weeks diagnosing my issue and still have found nothing. Here is my problem...
When moving forward or backward at a slow speed wheel turning or not, as well as coming to a stop, I get a clunking, creaking, popping sound.
I recently replaced my lower control arms (entire assembly), Upper control arms (w/ bj's), sway bar end links and bushings (Moog greasable). I have checked the torques on everything 5,6,7, ( lost count) times, always backing off a few turns before tightening to spec. I have even been doing the poor man power steering flush ( drain, fill, drive a few days and repeat) always checking for air.
My question is have any of you dealt with this before? I think it may be my sway bar end links which i will be replacing this weekend. if that doesn't fix it ill move to the tie rods as those are still factory at 135k miles. No i have not been able to get someone to turn wheel while i feel for popping. I will also be changing out the sway bar and SWB link bushings with Energy suspension bushings from Geno's Garage.
Any help, ideas, fixes would be greatly appreciated as I drive this truck daily with no other issues. Trucks alignment is still good at this point.
