I too owned an '01 6spd ETH HO QC Dually 3. 54 gears, I put just shy of 100k on it, it wasn't until I turned the power up drastically that had any issues with the clutch. I owned a 14,000lb 5th wheel at the time, and a GN that I'd regularly load to 20k. Once I changed injectors, intake, turbo, exhaust, and put stacked boxes on it, I started slipping the clutch while towing. But I was putting out over 500hp to the ground, kinda gotta expect the clutch to not hold when towing.
Peter at Southbend hooked me up with a new clutch, no problems after that.
I don't blame the stock clutch for it slipping though, I was putting out well over twice the hp it was designed to hold. At stock HP and even partially modified it held just fine for many thousand miles.
The Southbend was awesome, anybody looking for a clutch I highly recommend them!
*edit My '02 PLOW truck HO 3. 54 still has the original clutch at 150k miles. I tow with it as well, around 12k. Mildly modified with an EZ box and straight pipe, probably around 300hp.
