AH64ID
but I wonder why the GVWR of the 3500 isn't a little higher with the stronger transmission...
Same reason I am "rated" to tow more than the DRW variant of my truck... bean counters and executives don't look at that stuff.
If comparing to the 3500 SRW.....the tires are the limiting factor I'd imagine. 11,700 GVWR crew cab short bed 4wd.....12,300 GVWR crew cab long bed 4wd.I noticed that too... really makes you wonder. We all know that GCVWR of the 2500 is artificially determined by the 10K rating for a class 2B truck registration. The 3500 with the Aisin is certainly a more stout driveline than the 68RFE, but I wonder why the GVWR of the 3500 isn't a little higher with the stronger transmission...
I know the Dually is higher rated for more load in the bed.. However, since the dually weighs more it should have a lower rating ......... NOT WEIGHT Capacity in the bed.. That is MOOT on PULLING... If both pin weight are 3000lbs then the SRW should have a higher trailer pulling capacity due to the less weight of the truck on the SRW...
I know the Dually is higher rated for more load in the bed.. However, since the dually weighs more it should have a lower trailer tow rating ......... NOT WEIGHT Capacity in the bed.. That is MOOT on PULLING... If both pin weight are 3000lbs then the SRW should have a higher trailer pulling capacity due to the less weight of the truck on the SRW... The GVWR on the Mega Cab 3500 is 12300 lbs... the dually is 14000 due to the extra tires. But extra tires should NOT give a truck a Higher Pulling Capacity.... I think they got this "Backwards".. Just like the 68RFE has a higher rated payload because the truck's weight is less... However, the Chart is showing a truck that Weighs more having a higher tow capacity by 3300 lbs....BTW,,, this truck has a WEIGHT OF 8900lbs!!!this leaves 3400lbs to put in the truck.... Thanks gang...
So, in theory the SRW can tow the same and not hurt a thing.. Thanks for the reply..There are many reasons why, but the primary reason will likely deal with SAE J2807. A DRW has different test standards than a SRW and those test standards are "easier". Basically they can be SAE J2807 compliant with the exact same drivetrain at a higher weight.
SAE J2807 involves several tests and here are the differences from SRW to DRW.
Thank You for the explanation. So, really the SRW can tow the Same as the DRW??? 20330 pounds.....
12345678963
Acceleration.
0-30 mph: SRW is given 12 seconds and DRW is given 14 seconds.
40-60: SRW is given 18 seconds and DRW is given 21 seconds.
0-60: SRW is given 30 seconds and DRW is given 35 seconds.
Grade. Trucks must climb the Davis grade with a minimum ambient temp of 100°F. SRW's have to maintain 40 mph, while DRW's only have to maintain 35 mph.
This is why the GCWR and trailer ratings are different.
My 05 is rated like you mentioned, as both the SRW and DRW have the same GCWR.
I have a hunch why this is. Let's say a SRW is cornering fast pullng a load and a DRW is taking the same corner at the same speed pulling the same load.
Compare the rear tire sidewall flex when cornering of the 2 vehicles. I think the DRW will have significantly more stability and keep more tread on the road?
Exactly, Nick. The obvious answer is the 12,300 GVWR of the SRW vs. the 14,000 GVWR of the DRW. 1,700 lbs more of pin weight, cargo or passengers can be utilized in the DRW. An oddity dfb may have overlooked is the towing capacity of a 4x4 MegaCab SRW is more with the 68RFE vs the AISIN (16,800 vs. 16,660). Apparently there's 140 lbs more "guts" in an AISIN equipped truck----and subsequently 140 lbs less towing capacity.
The AISIN really shines with 3.73's over 3.42's and it shines most with 4.10's over 3.73's. When comparing all DRW trucks with 3.73's or 4.10's, the AISIN shines quite alot more over the 68RFE. The AISIN shines less in the SRW applications---where it is actually under utilized, IMO.
In theory, if you can support the trailer on your SRW wheels and tires.
The tires are rated for more than 3500 lbs each, but the wheels are only rated for 3500 lbs. 7K lbs on the rear axle is going to be your limit to towing.
I see where this is going... Due to the larger 5ver size, there would be more pin weight that the SRW is not rated for as far as GVWR, RAWR.......is this correct? If this is the case, then going to a higher rated tire would bring up the tow rating since the rear axles are the same etc..?
Are the specs listed here fairly representative of the RV you own???I will when the RV gets out of the shop.... weighed the truck as it sits with us in it...8900lbs....Leaves a 3400 capacity...
https://lakeshore-rv.com/keystone-rv/montana/2015-montana-3610rl-floor-plan/
If so....it's already at 2,905 lbs hitch weight---dry. If you have 3,400 capacity---I hope that includes your hitch installed. Throw a few items in the truck, and start plugging away at the RV's 3,975 lbs of cargo capacity....and you'll be over sooner than you think.
Basically yes that is correct.
The tires aren't your limit thou, the wheels are.
I just looked at the specs on your sig trailer...
It simply appears you have too much trailer for your truck and are trying to justify it on here... and no, I am not only talking about the published ratings.
Have you put your setup on the scale yet?
