For you folks interested in the 3-cylinder high idle. There has been some question as to what gets the feature to kick in, so I have been logging some data on cold start-ups this week. I am using the Alex Peper Car-Code software.
From what I can tell, it keys off of the initial IAT temperature, and not the running IAT. The traces show IAT doesn't get below 15 after it's running. I am posting the exported . csv file so you could load and graph it in a spreadsheet. If you have Car-Code software, you could playback the . dat file. I added . txt to both so they would upload.
In this trace, it was a 14 deg F cold start, no block heater. The 3-cylinder idle kicked in as soon as it reached 1200 RPM. You can see it in the RPM fluctuation... kinda neat. I let it run that way all the way until it kicked back to normal idle, which appears to happen once ECT reaches 173 deg F.
