yep I know of at least 4 that have it off of one truck, just can't wait for it to kick in. all it does it enable it when you download the program and it keeps it enabled after returning to stock.
there are three parameters that must be met...
IAT below 32
ECT below 140
and 0% throttle
The high idle still works when the parking brake is released. I almost found this out the hard way.
Ben
Just an update, it was -10 all night with 30+ mph winds, when I went out this morning it was -8 and still windy, started it up, took forever to fire, when it started, it went into high idle and then about 10 seconds later it kicked into 3 cylinder idle, wife called me and asked what was wrong with my truck :-laf , it works really well to warm the truck up, only idled about 5 mins. while I loaded some wood into the back of the truck, and after only driving about a mile the temp needle was starting to move, usually takes almost 5 miles to do the same.
Beach,
Borrow a Smarty from someone, download software from #1 - #9, then download it back to stock which will put the latest factory updates into your ecm, including the 3 cyl idle.
WARNING!!!!!
DO NOT UNDER ANY CIRCUMSTANCES DRIVE YOUR TRUCK WITH ANY OF SMARTY'S "CATCHER" SOFTWARES LOADED!!!! YOU WILL ENJOY IT SO MUCH YOU WILL SUDDENLY NOTICE YOUR WALLET $650 LIGHTER! AND A MUCH BIGGER GRIN ON YOUR FACE.
Godspeed,
Trent
3cyl *FINALLY* kicked in this morning, at -4 F. The temp got down to -10 or so, and I didn't have it plugged in to the timer.Ahhh... ..... I was unaware of the 2 stages. I haven't started it below 10 degrees since it's been Smartyized.
Just heard back from Bob... apparently 3 cyl only works on '98-'02. My Bad. Feel kinda stupid knowing I've been standing outside in -25 windchill weather waiting for my truck to make noise... ...
