3" rear blocks
Manual fuel lift (priomer?)pump
Car Seat options for 1st Gen (aka New baby on the way!)
HI All,
I'm looking to buy some 3" spacer blocks for the rear of my truck (factory one is 6" which is too tall)... . The blocks that go under the last leaf spring and above the axle tube... . I think the gassers use 3" ones but have not had luck in finding then in junkyards)..... Anybody out there wanting to get rid of some or know where some may be?
Thanks in advance for any and all help.
Andrew
be carefull what you get i think the blocks have an angle to them, to set the pinion angles. so if you go down in height (3") that will change the pinion angle !!!
did you check places like Rancho, skyjacker etc.
91 3" rear blocks
My 1991 ctd 4x4 has 3 inch rear lift blocks from the factory. I would trade for your 6" blocks if you want, or this might help you find what you are looking for.
NSteever, he's got them sold already pending he gets a set of 3" blocks. I already offered to trade my 3" blocks, I already have them removed sitting in the garage.
thanks Bill
Thanks Bill, I would like to put taller blocks on mine with 1/2 ton springs and air bags to keep it level with a load but maybe ride softer.
