Engine/Transmission (1998.5 - 2002) Staying with 3-inch Exhaust
98 - 02 Cruise control woes
Bhaf part number
petersonj
A while back I posted some concerns about how long an OEM muffler would last on the OEM exhaust system. I was mainly concerned if back pressure could be an issue as the muffler aged. I never really did get a definitive answer, probably because most people had moved up to 4" and 5" exhaust systems from the turbo back with either an aftermarket muffler, or no muffler at all.
So, I decided to do a little research on my own. I found a general statement that indicates Cummins does not want to see any exhaust back pressure above 3 psi. I connected a gauge to the 1/8" port on the exhaust elbow and strapped the gauge onto my windshield wipers and then went for a test drive. I made a few tests in which the engine was under full power (30 psi boost) at 2,000 rpm. The back pressure averaged 3.5 psi - not terribly high, but higher than the 3 psi limit. So, I knew I was going to get a new muffler - but which one?
This was back in November when I was contemplating all of this. What muffler to buy? Should I go to a 4 inch exhaust? What about the resonator? I really wanted to keep the truck exhaust system quiet. To further complicate things, I ran across a Black Friday special where PacBrake was offering a 4" in-line PRXB exhaust brake complete with an air compressor kit for $850. They never had sales like that before that I know of.
I already had a vacuum operated PacBrake that had logged over 460,000 miles - 70,000 miles on my previously owned '99 truck and the rest on my current truck. But, the PRXB exhaust brake has much better performance below 1500 rpm due to a design change. Well, I bought it.
Now – what to do with the exhaust system? One thing for sure, I wanted the system to be quiet. I finally decided to remove my vacuum operated exhaust brake, keep the three inch OEM exhaust system, remove the resonator permanently, install the PRXB 4 inch in-line exhaust brake, and replace the muffler. The decision as to which muffler to install was made easy through fellow Turbo Diesel Register member @Michaelsloft who installed a Walker SoundFX 18853 Direct Fit Exhaust Muffler on his ’99 truck with high miles. It turned out to be an excellent choice (for him, and for me).
Since the OEM exhaust system runs a short piece of 4” exhaust pipe between the removed resonator and the muffler, this is where I installed the in-line PRXB – just upstream of the muffler.
The end result…, even quieter inside the cab under all engine rpms (with or without use of exhaust brake), much better exhaust braking below 1500 rpm, and 2 psi exhaust back pressure compared to the previous 3.5 psi. Plus, the turbo now spools about 100 rpm earlier in the rpm range - a great performance boost for trucks with a manual transmission. I am glad that I stayed with the OEM 3 inch exhaust and an OEM style muffler.
I am hoping that this post may help anyone who wants to stay with the OEM exhaust system, but still get a little better performance without the additional noise.
- John
I had the same concern with installing it that far away from the engine, but apparently the difference is negligible, if any. And, the PRXB brake works much better from 1,500 rpm down to 1,000 rpm, so much better that slowing for 40 mph curves can be done easily in 6th gear now, where before I would always drop a gear for the same situation.
I do have an exhaust blanket on the exhaust manifold, turbo, and down pipe, so retaining the heat from compression braking could help - just a guess on my part.
- John
How well does the EB work so far from the engine? Seems like a lot of air to compress?
By keeping the 3" pipe, it is pretty much compressing the same volume of exhaust gas as it would with a 4" setup mounted further upstream.
- John
If you move it next to the transmission where the downpipe meets the rest of the exhaust, it will still brake about the same, but eliminate a second or two of delay. Also, it will cut down the "pop" sound you hear when the valve opens.
