I'm trying to decide which kit to get for my '98 5-speed. Right now I have a good plate, straight pipe and a cold air kit. Just installed my South Bend Con FE clutch a couple of days ago and my next mod is going to be govenor springs. Is there much performance difference between the two? (3000 vs. 4000) With the 4000 rpm kit do you need to change both the exhaust and intake valve springs to the heavy ones or just the exhaust valves? Also is it possible to float the valves with the 4000 kit if you were to just put your foot to the floor in a low gear and hold it there? In other words is there some sort of rev limit or is there a danger of reving too high and hurting the motor? Thanks.
