Well, I put the new spring in, breakover spring and had the breakover post welded. During the process I lost the top hat spring and replaced it with a genric one from the hardware store. The go pedal felt much softer I could blip the throttle and it would return to idle. Once I started driving the engine would get caught and stay at about 1700 to 2000 rpms. I could bring it back to idle by keeping it in gear and using the brakes to get the rpms down (I have a 5sp). I thought that maybe the top hat spring that I used was too weak and I replaced with a stronger one. I have the same symptoms only now I feel more engine vibration thru the pedal.
1) Is the softer pedal feel common?
2) What can I do to keep it from getting "hung up"?
Thanks in advance.
Art
Thanks in advance.
Art
