bigtan408 said:it depends on your ring gear. some of the d80's used a thin 3. 73 ring gear in connjuction with the 4. 10 carrier. arb does in fact make a 37 sline arb. hope this helps.
bigtan408 said:He Asked For Info On A D80 Which Is A 11. 5 Ring Gear. F-350 Duallys Came With A Dana 80
ata said:If you look at his Profile you will see SRW which stands for (Single Rear Wheel) which means he has a Sterling rear axle 10. 5" ring gear. If you do some checking you will find that the D-80 has an 11" ring gear. The only pick-up's 3/4 - 1 ton with a 11. 50" ring gear is the GMC & Chev HD's and the 2003 and up Dodge with the AAM axle.
BIG C said:Actually its a 11. 25" ring gear for my D80. But hey, Im still looking for that 37 spline 3. 73 gear locker. ??
