HOW ???
Whats needs done to garentee Smooth Operation With 370's on a 160 Pump ???
DM
DM
KLockliear said:Careful Forrest... you do realize there are quite a few differences between a 12v and an 03+, which allow the new trucks to handle more heat.
DieselMinded said:HOW ???
DM
Forrest Nearing said:yes, I'm fully aware... my point is that he's worrying too much if he's worried about 900-1150*F
Forrest
biggy238 said:WadePatton
Where are you pulling through that you have a steep grade to run, unless you head my direction into God's Country?
I try to keep up with the "what can I run on a grade" discussions because of the mountains here. I live directly north of Knoxville and head to Nashville on occassion.
I'd like to see the Mid Tenn chapter sometime.
Rams-n-Hogs said:Brian,
Are you going to the MDTDC picnic at the end of this month? I'll bring the '96 and show you how the valet switch works. If you're not going, we can try and get together some other time, if you want.
Jim
Bhale said:Well, after sliding my plate all the way back my egt's are still too hot when i'm hauling the camper. ~900 on a flat highway at 65 and a slight grade will bring it up 1150+ in no time. Passing is not an option. 35mph climbing the mountains gets me to 1200+ just maintaining speed.
Are there other injectors that'll drop the egt's by 200+ degrees and still keep the power or should i just got back to the 215's?
Thanks
Brian
SEmerson said:I pull fine with my 370's. I have to run lower gears on hill to keep the egt down though. The more rpm I spin the lower it will run.
