I have my truck apart for some head work and twins install and decided to send the injectors out to get the pressures checked. I was told 3 had low pressures (don't have numbers yet) and they had "irregular spray patterns" and scored valves. One option is to rebuild these injectors but it's not really worth the labor and parts since a new set is only $400. I've been happy with the 370s and don't feel like spending $1000 on other injectors right now so I think I'll just get another set.
What should I check for in the pump? Maybe pull the delivery valves and check them out? Anything else?
The truck was running fine when I took it apart so I'm not sure how much effect this had on performance. It did have the typical cold stumble but my fuel pressure was also a little low (10 psi loaded, 20ish rolling down hill) so a new overflow valve will likely help that.
Truck has 245,000+ miles. These injectors have 100,000+
Mike
Mike
