Greetings...
I RECENTLY posted the same title in the "911 FORUM. " A slave cylinder was found to be leaking and was replaced. However, this did not fix my clutch concerns. I need to pull the clutch. And, replacement will most likely be the solution. On a "whim of a prayer" I suppose it could be a pilot bearing or other less serious concern. Not likely. .
I'd base this new clutch on the "wishful dreams" of having all of the following
goodies: BANKS 4 INCH EXHAUST BRAKE, EDGE EASY, DD 1's, or (possibly but unlikely), DD 2's. Yes, I occasional pull a 28 ft trailer.
A southbend clutch seems to be the choice of TDR members. I want a clutch with long lasting/dependable characteristics, and comfortable usage too. I've also heard good things about a LUK PRO GOLD, which are a bit less $$$. Any thoughts ???
So,..... INSERT OPINIONS HERE I'd expect the real HP would be below 350, if I selected the DD 1's. Should I get the CON-0 (or) CON-OFE ?? I'm truly interested in your opinions. A dueling banjo competition is not what I'm pursuing. This in not new subject matter, but I'd appreciate your thoughts. A private post to me is fine too. Any of you TDR members with similar applications, please comment. Thanks... ...
Jim
