Governor springs are easy to install.
I've tried both methods and prefer the side port.
I did mine with the stock fuel plate. I loved the RPM gain, but I could still feel there was more potential.
Advanced the timing and while that helped the upper rpm it really dogged in the low to mid range.
I installed a #4 plate (developed for the "automatic" pumps with governor springs) and that really woke it up. I followed Piers' guidelines and installed the AFC housing only 2/3 forward to help control smoke.
The latest trend is to install a #10 along with governor springs as it defuels more in the upper rpm range to keep a better check on EGTs. One way to get a used #10 is when someone sells a Banks plate.
<b>A MUST have with governor springs is an EGT. </b>
Kris I see you're covered, but that is caution for the other readers. You can get into serious EGT troubles with an uprated plate combined with higher rpm. I have my #4 plate fully back and still hit 1600°F pre-turbo with 3,500 rpm.
Have fun and rotate those tires a bit more frequent
